Discussion topic: No response to handset on sky Q mini box.
Message posted on 18 Nov 2023 03:07 PM
Stuck on initial screen. Batteries good. Wifi good. Master tv working fine. Good sattelite signal. Can't look at settings because stuck on initial screen.
Message posted on 18 Nov 2023 03:14 PM - last edited: 18 Nov 2023 03:15 PM
Re: No response to handset on sky Q mini box.
Hi @Steve801
Make sure that the Home button on the Q remote isn't sticking. If that one and all others seem Ok the, with the mini on with green led
Try completly resetting your Bluetooth remote.
