Discussion topic: No recordings showing on mini box
This message was authored by: Athers1
I've had problems at ince I changed broadband provider. I had the main q box and mini linked by 2 ee120 extenders . Anyway day I got new broadband the mesh was servered . After trying to reconfigure the ee120's I gave up on that idea and bought 3 deco E4's that , from posts on net, are supposed to be able to create a secure sky q mesh . Again total fail . Mini box just said I had connection to the main box and internet connection ( both ticked ) no live tv , no program guide , no recordings no apps ect .
so I again phoned sky and I asked if a direct cat6 connection between the boxes would work . Said yes . So I've run cat6 between the two boxes . 40 metres .
now I've got live tv , program guide, apps and I can watch Netflix , Apple TV ect
BUT only thing it won't show is the recorded program list
anyone had this and  found a solution 🙏🙏🙏
Avatar for Athers1
Re: No recordings showing on mini box
Should read "I've had problems since I changed broadband"
You should be able to just run ethernet into each mesh node from each sky box and disable wifi on the sky boxes.
never seen a mini fail to list the recordings.
Avatar for Athers1
They are connected soley by cat6 cable and this is the best connection I've had since I got a new fibre provider
Indeed
wifi should work reliably but it doesn't
Avatar for Athers1
Re: Sky q mini will not show recorded programs
That's not true for over 12 months I have had Befibre and can only gets boxes working by putting main box on WiFi to router and connect main box and mini via cat6 cable . I tried your way but even sky engineer couldn't connect them any other way and he tried for hours
