3
This discussion topic has been answered Discussion topic: No recoedings on Sky Max Hub
This message was authored by: TechmanagerMal
Replacement Sky Max hub today - auto install appeared to have worked but minis (2) don't show recordings, message is - This service is currently unavailable.
Any ideas as they still show on the main box and connections appear ok.
Ps I didn't realise support was closed on Saturday evenings
Passing on the tips I have learned in over 25 years as a more than satisfied Sky customer.
This message was authored by: nigea99 Answer
Re: No recoedings on Sky Max Hub
hi @TechmanagerMal
Was your hub previous a SKY Max  ? In case you don't know SKY Q treats SKY Max hubs as 3rd party so rely on the wifi from the main box
Anyway, if you haven't already done it, may I suggest a full power down restart of you main box & when back, the minis
hi @TechmanagerMal
Avatar for TechmanagerMal
Level 13 icon
  • Thanks @nigea99 but it turned out a reboot of the minis was sufficient, for the complete answer but the points are yours.
hi @TechmanagerMal
hi @TechmanagerMal
Glad you are now all working again
