Discussion topic: No power in Sky box
This message was authored by: islandgirl
No power in Sky box
Just noticed last night that there is no power light on the box. It's not powering up at all. Changed the socket, checked the fuse in the plug, nothing happening. It's completely dead.
Re: No power in Sky box
@islandgirl  You'll needto call Sky if you've tried the usual trouble shooting.
You can call on 150 from a Sky Talk Line or Sky Mobile.
(UK) https://www.sky.com/help/home Scroll down and click on ‘Need more help’ and it provides a 0333 number
(ROI) on the same link change the flag in the very bottom corner to the ROI flag to obtain an 0818 number.
Stay on the line and don’t hang up if prompted to. Apparently the quieter times to ring are just after 7am or about 9pm.
Avatar for islandgirl
Thank you very much!
