Discussion topic: No network connection ,won’t accept password and have tried all options available online
Message posted on 03 Oct 2023 09:29 PM
I have no network connection, received a replacement box as my original box was doing the same thing so thought it was a box issue and i now have nothing at all. Cannot register my card because I cannot connect to the internet. I have tried all steps advised online but it's still not working. Tried password for internet and it's unable to connect, says check password and try again. Done so several times
Message posted on 03 Oct 2023 09:31 PM
Re: No network connection ,won’t accept password and have tried all options available online
Hi @MRJJ
Assume you have correctly carried out a Network reset on the main Q box.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
Message posted on 04 Oct 2023 12:23 AM
Plug it in over ethernet to at least get it activated.
Message posted on 04 Oct 2023 09:07 AM
Thank you. When i checked the router i could only see a reset button. I will check again.
Message posted on 04 Oct 2023 10:06 AM
Message posted on 04 Oct 2023 10:11 AM
Thank you very much. I will do this tonight and let you know how i get on. Thanks again.
Message posted on 05 Oct 2023 09:45 AM
Thanks for your help. All up and running now.
