Discussion topic: No internet on skyq
This message was authored by: Gerry581
Message posted on 04 Oct 2025 08:42 PM
No internet on skyq
No internet connection to Sky q box
tried all the resets can't watch any apps for example Netflix etc nothing loading in recordings either
Find out more
Message posted on 05 Oct 2025 08:01 AM
Re: No internet on skyq
Recordings should not be affected by tha so suggests a wider problem with the box.
you've done the Network Reset specifically? What happens when you tell it to re-attach to your wifi?
