Discussion topic: No internet on sky q hub or moni box
This message was authored by: Darren195
Sky q hud is not connecting to the Internet and so subsequently to mini box it's connected to anything and we can't watch any TV whatsoever. As you already know the speed is way below what is should be.
Re: No internet on sky q hub or moni box
Hi @Darren195
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router. Even if reset is not listed there is still an option to connect by WiFi to Sky or 3rd party router.
If you are on Sky Broadband with the new Sky Max (white) router then you need to connect it as if it is a 3rd party router.
If you are on 3rd party (non Sky ) broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band.
