Discussion topic: No internet on my sky box but all lights on Wi-Fi router fine
This message was authored by: Sarahmawds123
My Wi-Fi is working all 4 lights on but on my sky box saying no network connection I've tried resetting and unplugging at main wall also
This message was authored by: Bex8114
Re: No internet on my sky box but all lights on Wi-Fi router fine
mines same have you managed to get it working again ?
Avatar for Sarahmawds123
No I've tried also taking all leads out and replacing once unplugged from the mains and still no good(as advised on telephone call)now have to wait a week for engineer 🤦‍♀️
Sorry didn't mean last emoji
Hi @Sarahmawds123
Have you tried a Network Reset found in main Q box Home - Settings - Setup - Network.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
Thanx so much 🙌at first look couldn't for the life of me find a wps button on my router,it's on the side of the router and has now connected my device (I was pressing the wps button on q box not router 🤣🤦‍♀️)
what a dohnut I am!thanks for ur help
