Discussion topic: No internet connection on sky q box
Message posted on 07 Nov 2023 05:34 PM
We have lost our internet connection on our main sky q box. This has been happening for 2 days. Yesterday managed to reset snd reconnect but today it won't connect
Message posted on 07 Nov 2023 05:37 PM
Re: No internet connection on sky q box
No internet connection. Won't allow us to reconnect
Message posted on 07 Nov 2023 05:42 PM
Hi @Suzeeh
Are you carrying out a Network reset as follows on your main Q box?
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
