Discussion topic: No internet connection...but only on sky Q
Message posted on 31 Dec 2025 08:42 PM
My internet is working fine...but sky q tv saying it has no internet connection. Went to settings, tells me to hold down the WPS button om the router....there is no WPS button. In fact thete are no buttons full stop. What do I do?
Message posted on 31 Dec 2025 09:21 PM
Re: No internet connection...but only on sky Q
Hi @Zoz
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router. Even if reset is not listed there is still an option to connect by WiFi to Sky or 3rd party router.
WPS button on Sky router
If you are on Sky Broadband with the new Sky Max router then you need to connect it as if it is a 3rd party router.
If you are on 3rd party (non Sky ) broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band.
Message posted on 31 Dec 2025 10:31 PM
Hi Oldfella,
Thank you for replying. Sadly, as I said before... there are no buttons whatsoever (ie no reset button and no WPS button) on the sky broadband router. I cannot press a non-existent button!
Message posted on 31 Dec 2025 10:36 PM
@Zoz wrote:
Hi Oldfella,
Is it a Black Sky router @Zoz
If so, I posted a picture showing the location of the WPS button.
Message posted on 01 Jan 2026 01:42 PM
Hi Oldfella,
I don't know if I'm being daft...but I can't see where you have posted the picture...
Message posted on 01 Jan 2026 02:18 PM
