Discussion topic: No full satellite signal
This message was authored by: RJC2
Half the channels say no satellite signal ie Bbc1 sky max sky one channel 4 and it won't let me record series I have linked because it keeps saying failed no satellite signal
Re: No full satellite signal
@RJC2
With a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that:
🔹 wind and rain can affect the satellite signal and following adverse weather wait times for an engineer will probably be significantly longer.
🔹a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels (amongst the first to be affected may be TNT or GB News),
🔹a Sky Q box requires a periodic 'Keep alive' signal that is delivered via the satellite so if that isn’t received the box will close down until the satellite signal is restored.
Ignore, already answered.
LG B6 OLED 55” | LG UP75 LCD 43” | sky Q | sky Q Mini | SONOS Beam 2 | Apple TV 4K | EE Full Works FTTC
Avatar for RJC2
How do I book an engineer appointment?
@RJC2
If the link doesn't give you the opportunity to book an engineer then calling Sky will be your quickest option.
These are the current methods for contacting Sky. Some methods will be more appropriate than others depending on the reason for contact……
🟧 📞 Customer Services by dialling 150 (free) from either a Sky mobile or your Sky Talk landline if you have Sky Broadband. The forum doesn’t allow the display of other numbers but official numbers to Sky from the UK are 03 numbers which are usually inclusive from non Sky phones.
All calls will start automated (aka ‘the bot’) which may offer you the online help route or try to send you here to the forum. Stay on the line as long as possible and sometimes saying nothing when asked the reason for the call helps being put in the queue for an agent.
🟧online help via this link
🟧Sky Assistant 💬 should also be available via
🟧Social Media You can also get in touch via the messaging services on: Facebook, Instagram, or X (links at the bottom of the forum page).
🟩Note ~ ROI customers If you’re in the ROI make sure the flag in the bottom right of the link is showing the correct flag and change if required. The Sky Ireland phone lines are closed at a weekend.
