Discussion topic: No connection to sky tv
Message posted on 04 Aug 2024 12:11 PM
Received a new router. Cannot connect new WiFi to sky Q. WiFi working fine on phone but cannot connect to tv
Message posted on 04 Aug 2024 12:43 PM
Re: No connection to sky tv
@Chris307 wrote:Received a new router. Cannot connect new WiFi to sky Q. WiFi working fine on phone but cannot connect to tv
If it's not Sky broadband then you'll need to enter the requested details rather than use the wps button.
Message posted on 04 Aug 2024 12:45 PM
I should have added, if it is just a new Sky router then 'forget' the existing connection on the box and scan for the new one or use the wps button.
Message posted on 04 Aug 2024 12:51 PM
Hi @Chris307
