Discussion topic: No channel 419 or 583
This message was authored by: TC61
How do I get channel 419 and 583. I can see all orhers
Re: No channel 419 or 583
Can you confirm the channels you're looking for are Premier Sports 1 and Daystar (religious)?  What problem are you having when trying to view them?
Avatar for TC61
Just those two. Tells me there is a problem with my satellite signal. Have done the reset but no change
Avatar for TC61
Channels are Premier sports 1 and Daystar. Apparently they are on same frequency.
They're not on the same frequency but with a No Satellite Signal message there is likely to be a dish alignment fault, you will need to contact Sky and arrange an engineer visit.
Avatar for TC61
Thanks for your help. Will book an engineer
