Discussion topic: No audio from Sky Q to Bose 600 Soundbar
This message was authored by: GaryMc92
Hi, I've had an intermittent no audio issue between my Sky Q box and Bose 600 soundbar for a while now.  It seems to happen when I pause, rewind or fast-forward anything I'm watching on Sky Q.  The good old turn it off and on again is the only way I've been able to resolve this.  It doesn't happen every time and if was only every now and then I wouldn't mind, but it's turning into a daily task.
I've been on to Bose tech support with the assumption it's a soundbar fault, but as it isn't affecting any of the streaming apps on my TV, they're pinning it on Sky Q (tested rapidly jumping forwards/backwards on Netflix, Disney + and the audio has never dropped).  The only thing that I can put it down to is the Sky Q is occasionally getting stuck when a film is paused and then played, meaning no audio is passing through to the soundbar.  Not the most technical description but it's the only thing that makes sense to me at this point.  I've tried different HDMI cables, optical cables, CEC on/off and all of the different CEC options in the Bose app (attached).  I'm struggling to find anything else to test so any other help would be much appreciated.
Setup
Sky Q -> HDMI 1 -> LG CX -> HDMI 2 eARC -> Bose 600 Soundbar
Sky Q - Digital audio output HDMI - Dolby Digital Plus
LG CX - Sound Out set to HDMI ARC, Digital Sound Out set to Pass Through and eARC enabled
Re: No audio from Sky Q to Bose 600 Soundbar
Hi @GaryMc92
Just one observation although I don't know whether it's causing your issue.
Early LG's had issues with Audio passthrough.
Have you tried any of the other Audio HDMI format options (DD or Normal)
This message was authored by: FKM
@GaryMc92
Did you find a resolution to this problem? I have exactly the same setup (600, CX, 1TB box) with exactly the same problem. And it is only ever with fast forwarding / rewinding / pausing Sky recordings. Never anything else (as with yourself) e.g. tv streaming apps or PS5. I don't use Ultra HD (and therefore Atmos) as the Sky box upscaling is truly awful compared to the tv doing the upscaling and it's Ultra HD picture is too dark and poor. This problem is starting to annoy me now, so I hope that you've found a solution.
Avatar for GaryMc92
Hi @FKM,
Sorry for the late reply!
Unfortunately I still have the same issue.  I tried the optical cable again and although it is more stable than HDMI, the drop out still occasionally happens.  I've been speaking to LG support this morning and they've suggested what @oldfella said, but they also suggested changing the HDMI input audio format over to PCM (from Bitstream).  As far as I can tell, it limits the audio to stereo so Dolby Atmos isn't possible with this enabled.  That doesn't bother me as long as the drop out issue is resolved.  I've changed this over so I'll add a comment in here if it works 🙂
This message was authored by: Hicksville
I have the same issues, normally the sound cuts out every few days after fast forwarding through adverts. When it does work there is always blip sound prior to sound coming back.
i am using a Sony XR55A80L tv which is a year old, so not tv specific.
Thinking of just ditching the Bose soundbar, as fed with having to keep restarting everything.
aaaaarrggghhhhh
This message was authored by: DJWIG
I have exactly same problem Sky q box and LG tv using same settings but with the new Bose ultra soundbar so checking in to see if anyone has found the answer yet ?
Avatar for GaryMc92
Hi @DJWIG
Unfortunately, I couldn't find any solution.  All the checks I've stated before seemed to work short term, but after a while it went back to dropping out multiple times a day.  The only thing that did help slightly was changing the digital sound out to auto rather than pass through.
I returned my Bose soundbar and replaced it with the Sonos Beam gen 2 and the difference is night and day.  Unfortunately, it seems like it's a compatibility issue between the CX and Bose.
This message was authored by: Dizzyhites1
I have the same problem but I have a Samsung Tv, it has been working fine for years! Had a wire tidy up and it was fine. Then we had a power outage and a WiFi issue and I have to use the Bose remote to connect it every time I turn it on now I have to use the Bose remote every time I turn the TV on. I can't remember how I paired the Bose to the sky remote and can not see it anywhere, can anyone help me please?
hi @Dizzyhites1
One thing to check is that HDMI control is set to on on both your TV for the (e)ARC port and on your soundbar.
To re -set up your remote to work with the sound bar, try going to
Home - Settings - Setup  - Remote Control - SKy Q remote & then select  Control a Speaker System
If that fails then may I suggest you try a reset of your remote:
Press & Hold the 7 & 9 until the remote's light (red LED above the SKY logo button) flashes 4 times
Then press 1 & 3 together to go through to re-pair with the box and your TV *& Sound bar (after the TV)  - make sure it has line of sight of the box as until it is paired it uses Infrared
https://www.sky.com/help/diagnostics/sky-q-remotes/setting-up-remote
Thats interesting. For reasons i wont borebyou with, I upgraded my LG CX to an LG G5 and gave the CX to a family member. The Bose 600 Sky Q problem went away 😀 However I've also since swapped the Bose 600 for a Sennheisser Ambeo soundbar (gave the Bose to a different family member) ... no similar Bose like  freezing issues 👍 However, there is a slight lip sync delay on Sky Q channels - none on the PS5 or inbuilt tv streaming apps. It's hard not to see Sky Q as the common denominator in all this.
 I have the similar setup  sony oled tv and bose 600 soundbar. Same issues  sound cuts out after fast forward or pause. Complained to sky who sent a new box. Same issues with new box.
Solution is to ditch dolby digital/digital plus and just use normal. Sorted the problem. It's a shame sky engineering haven't got their act together to resolve this issue
