This discussion topic has been answered Discussion topic: No access to Sky channels in my pacakage
Message posted on 26 Dec 2024 11:41 AM
Suddenly I am unable to access Sky TV Channels. Ie Sky History. Sky Atlantic etc.
message appears at to-,of tv screen. Please upgrade subscription etc
never had this problem before till now. ?! Any ideas
Message posted on 26 Dec 2024 12:17 PM
@A.bx wrote:
Thank you. I have HD in package. Sky Signature and I have Sky Q Box relatively new
the only thing i can think is a message to activate Discovery Ch plus free of charge which I have partially done. May have upset the Sky channels?
For,past 3 years no problem
Hi @A.bx
Activating the free Discovery plus channel will have no effect on other terrestrial channels.
Have you tried rebooting your Q box?
Message posted on 26 Dec 2024 11:43 AM
Re: No access to Sky channels in my pacakage
Hi @A.bx
First check that you are not trying to Download or view HD or UHD content without the Q HD or UHD Subscription pack.
The Sky Q Sports pack and BT Sport if you subscribe through Sky are in HD as Standard.
Sky Cinema if you subscribe is also in HD.
Sky Signature includes BoxSets and Entertainment channels only in SD as standard.
Only free to air channels such as BBC, ITV etc are in HD. The Q HD pack is required for all other Sky Signature HD content, including Catch Up in HD, On Demand in HD and BoxSets in HD
If you do not have the Optional HD pack you need to change the Download to SD in All Formats (as HD is the default setting).
So that you do not need to do this every time it’s best to change your Download preference to SD in Home - Settings - Setup - Preferences.
This needs to be done on the main Q box.
Then if you want to download any HD content from free to air channels (BBCHD ,ITVHD etc) you can select HD in the All formats tab of the content . This will change the format for that particular download only but still leave your format to SD in preferences.
Message posted on 26 Dec 2024 11:53 AM
Hi @A.bx
