Discussion topic: No TV on Sky Q
This message was authored by: SimonDH
No TV on Sky Q
I have Sky Q, and everything works - broadband, apps, catch up, cinema, etc
Except the TV - i have no tv guide and no channels at all, not even the self-programmed ones
Is it the weather or my dish?
Re: No TV on Sky Q
Hi @SimonDH
Have you tried rebooting your Q box?
This message was authored by: reseng
Re: No TV on Sky Q
I have similar problem. Everything works but the TV. I have had this problem ever since I had sky. Every time I switch on the TV it shows no signal error. Sometimes I switch the Box off for a while and then on and leave it on stand by and the channels start showing, sometimes I am out of luck and despite switching itoff and on multiple times doesn't make any difference.
I am looking to go to another vendor.
Re: No TV on Sky Q
Do you have your own dish or communal?
Avatar for SimonDH
Re: No TV on Sky Q
Tried rebooting, but nothing new
Will try actually unplugging it to see if it helps
Re: No TV on Sky Q
'no signal' or 'no satellite signal'?
The difference is significant.
Avatar for SimonDH
Re: No TV on Sky Q
I get the no signal error at the very start, but i think that is just that the tv comes on before the sky box has booted up
Avatar for SimonDH
Re: No TV on Sky Q
Own dish
Avatar for SimonDH
Re: No TV on Sky Q
It says no satellite signal
Re: No TV on Sky Q
Hi @SimonDH
Work through the following link and if you cannot solve your issue it will lead to booking a Engineer.
Alternately, if you are on a Communal Dish you will need to contact your Landlord or Management company.
Avatar for SimonDH
Re: No TV on Sky Q
Booked an engineer - have to wait 10 days for the first available spot
Re: No TV on Sky Q
10 days is pretty good., recently a lot of people have been facing waits of 3 weeks or more.
Re: No TV on Sky Q
No satellite signal
