05 Aug 2024 03:24 PM
My TV screen says no signal. Nothing happens when I press the Home page. My Amazon prime is still working, so there is nothing wrong with the TV set and I have internet access on my boxes and other devioces, so its not an internet issue. I've tried turning the tv off and the swith on the wall. I waited a good 10 mis before switing it back on. In the past this has worked, but not today. I'd appreciate some advice. Thanks. Lorri34
05 Aug 2024 03:35 PM
Hi @Lorri34
Not sure if your Q box is switched on with a green LED?
Or is it switched on and stuck on the Home page?
