Discussion topic: No Sky Q TV signal
This message was authored by Mark336 This message was authored by: Mark336
No Sky Q TV signal
Sky Q TV no signal
This message was authored by Daniel0210 This message was authored by: Daniel0210
Re: No Sky Q TV signal
@Mark336
No signal or no satellite signal. They are totally different.
A message displaying ”no signal” tends to be generated from your TV and normally means your TV’s not seeing the Sky box on the relevant HDMI input.
If a message displays “no satellite signal” firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s likely to be a dish alignment issue so check the troubleshooting in this link
If you are connected to a communal dish you need to liaise with your building management company / landlord who will have their approved engineers to contact.
Remember, a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels.
▪️I AM NOT A SKY EMPLOYEE ▪️
