Discussion topic: No Sky HD channels on Sky Q
This message was authored by: Sagger5000
I've just had my sky dish installed and the driver has left. However when setting up my favourites I noticed I don't have HD Channels for Sky Showcase, Max and the other sky entertainment channels.
I have HD on Sky Sports and Sky Movies and the terrestrial channels but nothing for Sky's own channels. I've tried updating the software (which the installer said he'd done) but still nothing.
Can anyone help? Feel a bit shortchanged
Re: No Sky HD channels on Sky Q
@Sagger5000
Sounds like you haven't got the HD add-on.
Avatar for Sagger5000
Level 0 icon
I've paid for the HD package!
@Sagger5000
Try rebooting your main Sky Q box and see if that re-sets things.
~ press the 🏠 button
if that doesn't work and you've definitely subscribed to the HD add-on I think you'll need to contact Sky to refresh your card.
hi @Sagger5000
Check the 800s to see if you have them listed and can view.
it may just be a case of the smart switch of channel numbers not yet kicking in (which a power down reboot might cure)
This message was authored by: Sidl618
This is the case with mine. I have all the packages but for some reason all the HD channels (apart from the terrestrial channels) are in the 800s.
I've tried everything, resetting box, settings, and a card refresh but nothing has brought them up to the top of the EPG. Spoke to Sky yesterday who said this is just how it is (??) but at my other property all the HD channels are at the top as they should be. Can anyone help?
This message was authored by: twilight+princess
I believe the Sky sports HD add-on is separate from the other Sky Channels HD add-on so I would double check that.
If the HD channels are in the 800s & you select one does the 'you need to upgrade to view' message appear?
Virginia.
I don’t work for Sky.
If I have helped then please leave a like.
Hi Virginia thanks for the reply.
No, the channels themselves work fine, it's just that they're at the bottom of the Guide, which although isn't really a big issue it's a big annoyance to navigate to unless I learn the exact numbers. Sky seemed to think that it's correct, but I know it's not.
You're welcome.
Yes they should be listed under the correct channel numbers. Have you tried turning off the box, then unplugging it & leaving it for a few minutes then plugging back in again?
Virginia.
That makes sense that the SD channels would move to the 800s.
I have turned it off a couple of times in the past. Maybe I should leave it longer unplugged? On the phone yesterday we tried resetting the settings, and then refreshing the viewing card. The lady said these are the only two things she could do.
What would you suggest my next move is?
This message was authored by: Doc5907
@Sidl618  You can set the channels in the 800's that you regularly watch as favourites then you don't have to remember/worry about the epg numbers.
https://www.sky.com/help/articles/using-favourites-on-sky-q
Sky Q 1TB UHD
LG TV
Sky Mobile
