Discussion topic: No Signal at switch on. Light is on red permanently. Has happened before and Engineer had to visit
This message was authored by: Dave833
No signal shows on screen at switch on. Light is red.  Other Sky set ups in the house are working fine.
Re: No Signal at switch on. Light is on red permanently. Has happened before and Engineer had to vis
Hi @Dave833
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair to TV.
