Discussion topic: No Signal apart from channel 5
This message was authored by: Chris772
We have no signal, however ch5 still works every single other channel dosnt
nothing differnt blocking the dish
sky not answering the phones because of IT issues
Re: No Signal apart from channel 5
@Chris772
A message displaying ”no signal” tends to be from your TV.
A message displaying “no satellite signal” relates to your Sky Q box, so firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Also check the troubleshooting in this link
It may then give you the opportunity to arrange an engineer to check the alignment of your dish. If it doesn’t you’ll need to contact Sky to book an engineer appointment when the lines reopen.
If you are connected to a communal dish you’ll need to liaise with you building management company / landlord who will have their approved engineers to contact.
Note: A misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels.
▪️I AM NOT A SKY EMPLOYEE (even undercover)▪️
