2
This discussion topic has been answered Discussion topic: No Satellite signal
This message was authored by: Jack59
No Satellite signal
Carried out the normal checks and went further by unplugging all the cables and check in each connection seemed fine Wi-Fi working we've just cannot watch normal TV we have a communal dish but our next-door neighbour has sky also and that seems to have no problems
Re: No Satellite signal
@Jack59
With a “no satellite signal” message, check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely either;
▫️a dish misalignment,
▫️a failing LNB (on the arm of the dish),
▫️water getting into the cabling
so check the troubleshooting on this link
As you are connected to a communal dish you need to liaise directly with your building management company or landlord who will have their approved engineers to contact direct.
It’s worth mentioning that:
🔹 a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels (amongst the first to be affected may be TNT or GB News),
🔹 wind and rain can affect the satellite signal and following adverse weather wait times for an engineer will probably be significantly longer.
🔹a Sky Q box requires a periodic 'Keep alive' signal that is delivered via the satellite so if that isn’t received the box will close down until the satellite signal is restored.
▪️I AM NOT A SKY EMPLOYEE (even undercover)▪️
@Jack59
@Jack59 just a thought as you are on a communual dish can youtry going into the engineers menu
To enter the engineers menu do the following
press the home button then scroll down to settings and hi-light
do not press select/enter but press 001 then select this takes you into the engineers menu
then check that your LNB is set to SCR and not wideband if its set to wide band change it to SCR then reboot your box
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
