Discussion topic: No Satellite signal in Jersey
Message posted on 25 Dec 2024 07:56 PM
No satellite signal apart from BBC2 in Jersey. Have tried turning off at mains and no joy
Message posted on 25 Dec 2024 07:58 PM
Re: No Satellite signal in Jersey
@Careybf
If you are seeing a message of “no satellite signal” firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s almost certainly a dish alignment issue so check the troubleshooting in this link
It’s worth remembering that a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels.
Message posted on 25 Dec 2024 08:08 PM
@Careybf Post moved form the Mobile forum, what box do you have Sky+ or Sky Q
Message posted on 25 Dec 2024 11:07 PM
We have a Sky Q box
