Discussion topic: No Internet connection message on Sky Q
This message was authored by: Beard2
Been trying since yesterday to reconnect the Internet connection between Sky Q box and router by following the instructions on the screen, but to no avail. I've even tried to reboot everything with no luck. I don't know what else to try. Can anyone help, please?
Re: No Internet connection message on Sky Q
Hi @Beard2
