Discussion topic: No Connection & not able to reset by holding WPS button down
This message was authored by: Phil7990
Re: No Connection & not able to reset by holding WPS button down
They sent a white router. Is there a different process for a white router or should i ask them to replace it with a black router? That's if i can get hold of them!
@Phil7990 try not using wps with the white router and treating it as a third party router
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
This message was authored by: Redcat88
Thanks, this worked for me too. The WPS was just resetting my network name and password to default and the only way I could connect Q box was by the "other provider" options.
This message was authored by: Tanyabr
This resolved about three hours of [removed] signal and no sky q.
this fixed it in 10 secs!!
Moderator Actions: Removed inappropriate languge
This message was authored by: Gortonlad
This worked for me. Thanks for posting.
