3
This discussion topic has been answered Discussion topic: No BBC hd on sky Q hd box 16th Jan
This message was authored by: PSD
BBC channels have dissapeared today 16th Jan from Sky Q HD.
All other HD channels OK
Re: No BBC hd on sky Q hd box 16th Jan
@PSD
Have you tried rebooting your main Sky Q box?
~ press the 🏠 button
@PSD
Avatar for PSD
Huge big thank you to Daniel.!,,
Yes that worked thanks.
It would be good if Daniels simple solution was posted somewhere obvious  by Sky or BBC.
@PSD
✔️the reboot sorts many of the minor glitches.
