Discussion topic: New sky q box not showing the usual subscribers to prime tv
This message was authored by: Sshs
Had a new sky q box installed to replace a faulty one and now unable to watch prime tv as it just has my old expired account on screen and not the usual three fully paid members
Re: New sky q box not showing the usual subscribers to prime tv
hi @Sshs
In which case you have logged into the app with the wrong/older credentials.
You will need to logout :
Left Arrow to activate the left hand menu
Scoll Down to Settings & Press Enter
Scroll down th elist of Settings - Sign Out should be at the bottom of the List & Select it
Once Signed out , you will need to sign in with your Newer Account
Avatar for Sshs
Thank you but is that on my mobile as can't see where to do that on the tv app
No  that is in the Prime App on the SKY Q box
OOps @Sshs
I am hopeless with my Left & Right
I have edited my post as I should have said Left Arrow
Avatar for Sshs
Thank you
