Discussion topic: New sky q box fitted tv wont start
This message was authored by: kieron+1
Recently had a new Sy Q box to replace the old one. Now the TV won't start with the Sky remote have to use the actual TV remote to select the hdmi 2 port. Even then it doesn't fire up so I have unplug everything for 30 seconds or try removing the pink hdmi from the sky box and plugging it back it. A night mare help anyone pleasr
I'm sure it's a simple fix
It worked OK when the engineer was there but there again he wouldn't be turning it on and off repeatedly
This message was authored by: Lisa-P1987
Re: New sky q box fitted tv wont start
Lisa - Sky Tech Team Expert
This message was authored by: Mr+Flibbles+86
We are still looking to help you. If you need our support let us know and we can re-escalate to our chat team. Your invite has been closed now. Thanks
Avatar for kieron+1
after a conversation with Sky today they say my new sky Qbox is at fault and are sending me out a new one
But now the sky sound box bar won't respond when the sky remote is use
Help
This message was authored by: kop32
Hi @kieron+1 ,
I take it you have tried resetting the Sky remote and re-pairing it again?if not try as follows.....
On your Sky remote press and hold 7 & 9 together until it flashes 4 times, then press and hold 1 & 3 together and then follow the on screen prompts.
Back to Sky Q and 2 mini boxes after a failed attempt at Sky Stream (again) , VM 1 gb Broadband and Google Nest WiFi Pro.
Help
@kieron+1 if sky are sending you a new box by DPD then remember to REMOVE THE VIEWING CARD from your old box and check that you receive a new power cable with the new box
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
