Discussion topic: New seasons starting, no recordings....
This message was authored by: KathyDe
Why is it that my Sky Q box isn't restarting the recordings for the new season episodes?  Only found out by accident and it's really annoying.
Avatar for KathyDe
Re: New seasons starting, no recordings....
And yes, the shows where on repeat record....
Exactly to what channel and shows are you referring @KathyDe
@KathyDe
Sometimes series link doesn't follow on to the next series. I had to manually re-enter the new series's of the Chicago franchise.
@KathyDe
Content has to be appropriately tagged by the provider so that the Sky platforms know it's supposed to be recorded.
Typically anything you've missed will be available on-demand.
Even on sky +hd I've never been able to rely on this function as it's completely hit and miss so always set new series to record from scratch
