Discussion topic: New model tv to connect to multi room box
This message was authored by Wizzkid This message was authored by: Wizzkid
I currently have an old Toshiba tv connected to my multi room box, how do I connect a different model tv  such as LG to it please?
This message was authored by kop32 This message was authored by: kop32
Re: New model tv to connect to multi room box
Hi @Wizzkid.
You'll need to reset your Sky remote and then re-pair it with the new TV as follows.....
On your Sky remote press and hold 7 & 9 together until it flashes 4 times, then press and hold 1 & 3 together and then follow the on screen prompts.
Sky Stream x 3, VM 1 gb Broadband and TP-Link Deco X50 AX3000 Whole Home AI-Driven Mesh Wi-Fi 6 System
This message was authored by Laing1 This message was authored by: Laing1
@Wizzkid if you mean how to connect your new TV to the mini box all you need to do is to unplug the HDMI cable from the back of your old Toshiba TV then insert it into a HDMI socket on your new LG TV then on the LGTV you need to set the source to the HDMI socket you connected the box to then
follow the instruction @kop32 gave you for setting the remote up
