Discussion topic: New fibre
This message was authored by: Wehmeyer73w
New fibre
We got fibre in and the box is right by the TV but now SKY Q does not work. The box switch off
Re: New fibre
@Wehmeyer73w wrote:
The box switch off
Not sure what you mean by this?
But if the router is near the Q box then use Ethernet.
Avatar for Wehmeyer73w
Re: New fibre
The box switch off by itself and we only can use one remote where as before we used 2
Re: New fibre
This would have nothing to do with getting fibre installed as fibre could not affect how the remotes work with Sky Q.
Re: New fibre
Which fibre provider is it?
and is the Q connnected over wifi or wired?
