Discussion topic: New build wanting sky but told may not be able to have dish installed
Message posted on 17 Apr 2024 11:56 AM
Wanting to get sky Q but I'm in a new build, loft isn't boarded out. Been told may not be able to have it fitted as loft isn't boarded out but neighbours 2 doors down have it, anyone know if this is true? Or in a new build with no boarded loft that has sky Q? Thanks!
Message posted on 17 Apr 2024 12:05 PM
Re: New build wanting sky but told may not be able to have dish installed
The loft does not come into it. Sky engineers won't go into a loft but there should be no need for them to do so.
Message posted on 17 Apr 2024 12:08 PM
Thank you,
so I should be able to have it installed?
Message posted on 17 Apr 2024 12:09 PM
Some developers don't allow dishes at all which doesn't seem to apply as you say other properties already have a dish.
Message posted on 17 Apr 2024 12:25 PM - last edited: 17 Apr 2024 12:25 PM
The issue with lofts tends to come up where the developers have 'helpfully' installed ducting / cabling which ends up there, but a Sky installer isn't permitted by their own safe working rulebook to reach this.
Message posted on 17 Apr 2024 01:15 PM
Coax can be left rolled up in the loft coming from tv aerial points in the house as often a loft tv aerial is seen by some builders an as "optional extra". Sky wont use this anyway.
Message posted on 17 Apr 2024 01:27 PM
@Els25 If your newbuild has already had a wall mounted media plate installed in the room where you would like a Sky Q receiver to be installed, and the coaxial cables feeding that media plate presently just terminate in your unboarded loft.
Then, there is nothing to stop you employing a suitably qualified local satellite specialist to fit a suitable satellite dish, with a 'Wideband' LNB, and check if you require the media plate to be altered in order to allow the full bandwidth of 'Wideband' LNB satellite transponder signals to pass through it correctly.
Godfrey.
