Discussion topic: New TV fitted yesterday. Worked fine to begin with. Now says 'no network connection' but my PC is
Message posted on 12 Sep 2023 10:09 AM
New TV fitted yesterday. Worked fine to begin with. Now says 'no network connection' but my PC is working fine
Message posted on 12 Sep 2023 10:27 AM
Re: New TV fitted yesterday. Worked fine to begin with. Now says 'no network connection' but my PC
@john44 Do you mean Sky Q was fitted as Sky don't install TV's at all?
Message posted on 12 Sep 2023 10:33 AM
Yes, Sky Q was already there but .no network connectio' was a periodic message with the old TV too.
Message posted on 12 Sep 2023 10:34 AM
So the message is coming from the Q, on its "homepage" not the TV?
Message posted on 12 Sep 2023 12:35 PM
I guess so.
Message posted on 12 Sep 2023 12:42 PM
@john44 wrote:I guess so.
Standard issue Sky wifi problem then. One of many. Are you on Sky BB?
Message posted on 12 Sep 2023 01:33 PM
I fear so. They are sending a replacement ether net cable to see if that solves the problem.
Message posted on 12 Sep 2023 05:49 PM - last edited: 12 Sep 2023 05:51 PM
To connect the Q to your router?
Did they disable wifi on the Q? Or is it using that to talk to minis?
Message posted on 14 Sep 2023 05:23 PM
New ether cable from router to the outside world seems to have solved the problem. Thanks for you r support.
