4
This discussion topic has been answered Discussion topic: New Sky Q remote won't turn tv off
This message was authored by: Catherine.B39
Had a new sky Q box yesterday and now I have awful trouble turning the TV off with the  new remote , I have to switch it off and the back of my TV via the buttons , so annoying.  Is there a way to do it please?
Re: New Sky Q remote won't turn tv off
Hi @Catherine.B39
Once the remote is correctly paired,
A short press on the standby button turns the Q box On or Off.
A long press (about 3 secs) turns the Television On or Off.
Hi @Catherine.B39
Hi @Catherine.B39   Have you paired (1 & 3) your new remote to your TV?
And to the box? Does voice control work?
also, have you no longer got the TV's remote if you have to use the hardware buttons? What about volume?
Avatar for Catherine.B39
Hi guys thanx for your responses I've tried all the tricks but nothing won't turn it off and on  x
