Discussion topic: New Sky Q Box won’t detect 4K TV
Message posted on 18 Apr 2024 04:46 PM
I had a visit from Sky today as i was having problems with Q. The upshot is my main box was changed to the v3 from the v1.
All seemed well until i tried to watch a movie in UHD. At this point i realised that the box is stuck in 1080i mode. I cannot change to 2160 or even 1080p (the former says a 2160 capable set could not be found, the latter results in a blank screen). I am connected directly with an HDMI cable into an LG OLED TV that is capable of 2160 @ 60fps using the same HDMI cable that was connected to my previous main box. Any suggestions very welcome!!
Message posted on 18 Apr 2024 04:54 PM
Re: New Sky Q Box won’t detect 4K TV
@philam2-Mobile2 wrote:. Any suggestions very welcome!!
What's the model number of your box? https://www.sky.com/help/articles/sky-software-updates
They may have given you a non-UHD box...
Message posted on 18 Apr 2024 05:01 PM
@PandJ2020 no it's definitely the right box (it gives me the option to select UHD etc). I'll have to try with a different tv / cable to narrow down the issue I guess 😕
Message posted on 18 Apr 2024 05:36 PM - last edited: 18 Apr 2024 06:24 PM
The V1 box was not HDR capable. (Edit. Corrected with credit with credit to @nigea99
Therefore it could be that the HDMI cable is not HDR capable due to its length or specs.
Also are you sure that the LG TV HDMI input for the Q box is set for UHD/HDR
Message posted on 18 Apr 2024 05:44 PM
@oldfella maybe I had the V2 box previously then - but I have been happily using UHD with Sky Q on the same TV for the last couple of years, and the fact that I can't even select 1080p now makes no sense at all. I have even tried with a different tv / different HDMI cable and have the same issue - so definitely the new box rather than the settings on my existing equipment that is the root of the problem 😞
Message posted on 18 Apr 2024 05:48 PM
Yes if it was V2 then this was UHD capable
Message posted on 18 Apr 2024 06:18 PM
If it was a 2TB then it probably was V1 box (Hardware version 32B0xxx) which are UHD capable but not HDR capable
Certainly worth trying a different HDMI lead as well as double checking the HDMI input settings on your TV
