Discussion topic: New Sky Q Box, questions??
Re: New Sky Q Box, questions??
@Stephen+Mourton wrote:
@Daniel0210 @Thanks for the link.  The instructions tell me to press the Home button and scroll down to Music then Your Music.  I pressed the Homebutton but when I scroll down there isn't a Music option just Audio and Music but nothing in there that says Your Music
hi @Stephen+Mourton
In the Audio &  Music you should have an entry 'Your Devices'
Select this & Scroll right to highlight Play your Music using Airplay - it then lists details including  either 1TB or 2TB Box
This message was authored by: Stephen+Mourton
@nigea99 @Thanks for that.  It says I have 2TB Box 3803 box.   Is there an upgrade for that please?
Hi @Stephen+Mourton
The 3803 is just a unique number to see your box/use  when trying to connect
The Type of 2TB (as indicated in the link) is shown in the Hardware Versin :
If it is 32B0xxx then you have a (V1) UHD but non HDR 2TB Box
If it is 32B1xxx then you have a (V2) UHD HDR 2TB Box (which has a separate Power supply)
If it is 32B2xxx then you have a (V3) UHD HDR 1TB or 2TB Box
Thank you.
I have two other question from comments made in this thread.
Firstly what is a DR Stream please?
Secondly how do you update your signature as mentioned in an earlier post?
@Stephen+Mourton
Click on your avatar picture in top right corner. Click on My Settings. Click on My Profile. There should be a Signature box. You have to reach level 8 for some changes.
Thank you.
The DR stream is where the latest available software to download is  (i.e. what gets used when you manually initiate a software update)
AFAIK this is stil only at Q220
