2
This discussion topic has been answered Discussion topic: New Sky Q 2TB - have to keep restarting at the mains.
This message was authored by: Orange69
Hi all.
Recently had a new 2TB box fitted in order to add more mini boxes.
had worked fine initially. But all this week, I have to keep restarting the box. Eco and Active modes had already been turned off.  Usually I press "home" and the A/V Reveiver and TV turn on and life is wonderful! However, now everything still turns on, but no picture from Q box. If I put the box into standby, the sky Home Screen displays for a few seconds, then goes blank. So I turn off the the 2TB at the mains, restart, then it works fine.
many ideas?
Thank you!
Avatar for Orange69
This message was authored by: Orange69 Answer
Re: New Sky Q 2TB - have to keep restarting at the mains.
Hi all.
Problem solved!
I spoke to Sky yesterday. Very helpful chap. Suggested to eliminate the A/V receiver. So plugged the HDMI direct from the 2TB Q box to the TV and voila - it worked! I'm still a little miffed as to why, because when I reset the SkyQ box it worked. But anyway, the amp was the issue.
Thank you.
This message was authored by: Greenfingers001
Hi there @Orange69 , I’ve escalated your post to our Community Messaging team who will invite you to a private chat shortly and help you with this.
Avatar for Orange69
Hi all.
Problem solved!
Thank you.
