Discussion topic: Never have satellite signal for CNN
This message was authored by: SineadOConnor
I've tried everything . Every other channel is fine ...even in good weather I can't access cnn
Re: Never have satellite signal for CNN
Do you have any problems with GB News and Bloomberg? They are broadcast on the same frequency.
It is likely to be a dish alignment issue, even if only those channels are affected (it's very common for dish alignment issues to only affect a certain frequency) and will require an engineer visit.
Avatar for SineadOConnor
No just cnn (506)
What happens when you try to access CNN, are there any on screen messages?
No satellite signal received .this happened a year or 2 ago . Engineer adjusted the sky dish outside and it fixed it . Pity because the cnn is the channel I want to watch most
@SineadOConnor
In that case you probably need another visit.
If you’re seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that:
hi @SineadOConnor
It is strange if you cannot get CNN but able to watch Blomoberg & GB News - as @xenon81  says they share the same transponder
This transponder is one of the weakest in the UK & Ireland as it is a European wide beam rather than UK/ROI  targetted
Although a long shot,  try adding it as a manual channel using the following paramaeters
Settings - Manual Tuning - Add a channel
then set
Frequency : 11671
Polarisation: H
Symbol Rate: 23.0
FEC : 2/3
Standard DVB-S2
Modulation : 8PSK
Then  Press - Find channels
It should find CNN HD  - Select it & press Save Channels
Then to see it - go back to Settings - Manual Tuning & Select CNN HD and press Select
This message was authored by: Godfrey
@SineadOConnor  This is an example of a typical satellite transponder reception when it is using the tight Uk & Ire beam;
The LBER (uncorrected signal errors) are less than 1 in 1 million samples.
This is an example of the CNN satellite transponder reception when it is using the wide Europe beam.
The LBER (uncorrected signal errors) are averaging around 4.4 errors in every 100,000 samples, requiring the Viterby Forward Error Protection to gently start to work to remove them.
As you are a keen watcher of CNN, if you live in an area of the country where Sky fit the smaller Zone 1 satellite dish it might be worth considering the purchase of a larger, higher gain, Zone 2 dish which is available from ebay for around £45, and ask your Sky engineer to fit this higher gain dish when they attend to correct the aim of your existing Zone 1 dish.
Godfrey.
If nothing compares to CNN, then it might be worth paying £19.90 for annual access online: https://edition.cnn.com/specials/live-cnni-uk/
If your TV has a web browser (many smart TVs do), you could watch that way or use the CNN app which is available on some LG and Samsung TVs, Fire sticks, Roku etc: https://edition.cnn.com/about/live-tv
LG B6 OLED 55” | LG UP75 LCD 43” | Sky Q | Sky Q Mini | SONOS Beam | EE Apple TV 4K | EE Full Works FTTC
@stereohaven
I see what you did there 😀
@Daniel0210 wrote:
@stereohaven
Thank you, I'm very proud of that one, helpful and witty! 🤣
Might print it off and frame it... 😜
