5
This discussion topic has been answered Discussion topic: Network connection. My router is not shown but another router is?
This message was authored by: Cockneyboy46
For some reason my BT router which has been on my sky for many years is not there. It's showing a Sky router that I do not know why?
This message was authored by: Chodley Answer
Re: Network connection. My router is not shown but another router is?
Have you got a Booster?
This message was authored by: Stephen+Mourton
Do you mean, your SkyQ box which previously found your BT router but now cannot find your BT router but is finding a Sky router instead?
Avatar for Cockneyboy46
Yes for some reason it shows a Sky router that is not mine
If your BT router is not being shown and you don't own a Sky router, the only possible reason I can think of, it has found the Sky router because it is showing the only one it can find which may well belong to a neighbour.  If that is the case then regard the Sky router a red herring and try and find out why the connection between your tv and router is not working.
All sorted thank you
