Discussion topic: Netflix wont load down stairs on main q box unless i unplug powe lead every time yet on mini q box
Message posted on 03 Nov 2023 07:34 PM
Netflix wont load on main q box unless I unplug 1st yet connects 1st time in bedroom on mini box ???
Message posted on 03 Nov 2023 07:35 PM
Re: Netflix wont load down stairs on main q box unless i unplug powe lead every time yet on mini q b
Hi @Andy+johns
Try a Reset Settings in the main Q box hidden menu.
