This discussion topic has been answered Discussion topic: Netflix wasn’t loading so did a reset and now I can’t get sky on my tv and the remote doesn’t work
Message posted on 21 Aug 2024 06:21 PM
Netflix was spinning so I did a reset and now I've got a message on my screen saying 'accessibility on Sky Q' with options of settings and 'skip & set up later' but my remote won't let me select either now. Yes the batteries are fine, and it worked fine before I did a reset. Any ides?
Message posted on 21 Aug 2024 06:25 PM
Hi @Lizawatts
Hi @Lizawatts
Message posted on 21 Aug 2024 06:39 PM
Re: Netflix wasn’t loading so did a reset and now I can’t get sky on my tv and the remote doesn’t wo
Thank you! I think I might love you! Sky is back and the reset has fixed the Netflix issue!!
