Discussion topic: Netflix troubleshooting - can't display installer
Message posted on 10 Mar 2023 11:30 AM
I recently swapped my Netflix over to Sky but can't access it on my Sky Q box. When I click on the App it just keeps spinning. When I go into Sky Help it says refresh by hitting home, highlight settings and then do 0,0,1 to display the Engineers Installer menu, but nothing is displaying. Anyone any workarounds please?
Message posted on 10 Mar 2023 01:31 PM - last edited: 10 Mar 2023 01:32 PM
Re: Netflix troubleshooting - can't display installer
Hi @TRINSK
You need to press Select after the 0 0 1
Refreshing the Apps in the Hidden menu.
Select Apps
then highlight Refresh all Apps on this box.
You'll see a message that says, 'Your apps are being refreshed'. This will stay on screen until you press Dismiss to return to normal viewing
It’s recommended waiting at least 5 minutes before doing so.
Refresh Apps can take up to 24 hrs to complete .
Message posted on 10 Mar 2023 02:44 PM
Thanks so much for your help.
