10
This discussion topic has been answered Discussion topic: Netflix stopped working on main SkyQ box
This message was authored by: SKYPJ
I have the main SkyQ box and two mini SkyQ boxes. Netflix has stopped working on the main SkyQ box. I can select the app but it just sits with the circle rolling. Same router on all boxes.
Re: Netflix stopped working on main SkyQ box
@SKYPJ wrote:
I have also just tried the 'Refresh all Apps' which did not fix the problem.   Is odd that the only issue is Netfix on thsi box, all other features seem fine.
Hi @SKYPJ
Try a Reset Settings in the main Q box hidden menu.
Hi @SKYPJ
Assume you have tried rebooting your main Q box.
Avatar for SKYPJ
Level 2 icon
Thank you for your reply. I have rebooted but this has not solved the problem.  Everything else other than Netflix is fine on the main box and the mini boxes work fine including the Netfix app. Only on the main box I can select the Netfix app, it seems to try to start the app, the Netfix logo appears as normal but it sits there with a circle rotating underneath it.  Other apps work fine including Amazon, BBC, ITVX etc.  the settings section on the main box show all is fine; network etc.
Avatar for SKYPJ
Level 2 icon
Hi @SKYPJ
Avatar for SKYPJ
Level 2 icon
Hi @oldfella , we are making progress, I have followed your instructions and reset the box.  I was then presented with the login screen for Netflix, but, my password has capital letters and the skyq box Netflix login doesnt offer any option to set a capital letter.  Can you help on this also?
Avatar for SKYPJ
Level 2 icon
Resolved! thank you @oldfella .  I worked out the capital letter issue, it is the 'up' arrow on the lower left of teh on screen keyboard.  All working again, I really appreciate your assistance.
This message was authored by: Stan1958
Tried your reset for the Sky Q box get Netflix working and lost all the apps except Peacock, am i suppose to wait for the apps to appear again or is there something else I'm suppose to do?
Avatar for SKYPJ
Level 2 icon
Hi @Stan1958 , the same happened to me.  I waited and also clicked the Peacock app, to see if it worked, and then all of a sudden, all apps reapeared.
Thanks for your help, all apps back and Netflix working.
This message was authored by: cai129
Absolute junk... two months ive had this issue and its ONLY SKY Q box that Netflix has issues with, complained to sky and they sent me these instructions then blamed Netflix!!
