Discussion topic: Netflix is slow to connect and then when it does it throws you out. Anyone having issues?
This message was authored by: Keith211
Message posted on 10 Sep 2023 10:20 PM
Netflix is slow to connect via Sky and then when it does it throws you out. Anyone having issues?
Find out more
Message posted on 11 Sep 2023 07:22 AM
Re: Netflix is slow to connect and then when it does it throws you out. Anyone having issues?
Hi @Keith211 Try rebooting your router by removing the power cable for 30 sec then reconnect to reboot, then reboot your main SKYQ box by turning the power off at the socket for 30 sec then turn back on?
