Discussion topic: Netflix has encountered an error. Code: tvq-st-102
Message posted on 24 Jun 2024 03:20 PM
Netflix not loading on mini box
Last 3 days I can't get netflix to load in my bedroom on mini box, I've tried resetting the mini box unplugging etc and also the main box to no avail.
I've tried reloading my WiFi and also done the hidden menu option, nothing works.
Why can I watch netflix downstairs on sky Q with no issues but it won't load upstairs .
I'm disabled so I spend most of my days in bed so need netflix to work. Haven't had ur now for 3 days, what's going on?
Please help
Message posted on 24 Jun 2024 04:01 PM
Re: Netflix is no longer working since yesterday Sunday 24rd Juneunday
Yep just the red circle, so I am paying for something that i cannot use, how do I get compensation
Message posted on 24 Jun 2024 04:05 PM
Re: Netflix: Red Spinning Circle on Launch
How often should i be resetting my settings, this is getting rediculous
You are experiencing the problem on Sky Q. There are apparently no issues watching it be other means so I doubt compensation will be offered.
Message posted on 24 Jun 2024 04:43 PM
Re: Netflix not loading on mini box
Please help
@Mete78 I have moved your post to a larger thread all about this problem of Netflix not loading. It is a strange problem as it can affect 1 box and not another. Sky have a fix for the problem and it will be rolled out in the next software update
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 24 Jun 2024 06:58 PM
@WendyHinton wrote:Wouldn't just be simpler for Sky to fix it given they are charging for it?
They maybe charging for it but it's still alot cheaper via Sky then Netflix.
Would you pay £17.99 direct from Netflix to watch the red spinning circle on your Sky Q box ? I'm sure you'll find a different device to watch it on
Message posted on 24 Jun 2024 07:04 PM
@nobbynobby wrote:TO EVERYONE:
I've just had a fix from a Sky Customer Services adviser that worked.
Go to:
Settings / Status / Network Connection / Network Setup /Reset
Even if you get the message that says your Network is fine, confirm the reset.
Worked straight away after reconnecting (you'll need to press the WPS button on the router)
It'll be pretty rubbish if this is the only thing that works until a software update, but at least it should get you going for a while.
That's not a fix it's workaround no different than changing the DNS to 8.8.8.8 or 1.1.1.1
Message posted on 24 Jun 2024 07:11 PM
I had the spinning thing on Netflix about 15 minutes ago.
I went on Settings - click that - click System info then click Software version and move to the right and click setup which takes you to Software download which I did.
My software version now is Q260.000.05.00L (5sdpqlw)
Following the update Netflix now works - in the meantime I watched Netflix on my fire stick sad but you sometimes have to use an alternative.
Message posted on 24 Jun 2024 07:18 PM
The update whereby the fix will hopefully be included is Q270.
Message posted on 24 Jun 2024 08:05 PM
Netflix not loading on sky Q
For the last couple if weeks my netflix will not load and stays spinning on the inital screen. I can fix it by doing a hard reboot on the box but don't want to have to do this everytime.
Are there any solutions?
Message posted on 24 Jun 2024 08:08 PM - last edited: 24 Jun 2024 08:09 PM
Re: Netflix not loading on sky Q
@Lou761 I have moved your post to the large thread all about the same problem you are having if you look at post 2 on page 1 of the thread the one marked as the answer it will let you know what the current situation is
Message posted on 24 Jun 2024 09:09 PM
I know this is a known fault and due to be fixed in the next software update, but I'm paying for a service I cannot us. Are we going to be getting a refund for the amount of time this service is down for?
Message posted on 24 Jun 2024 09:38 PM
When is the update available to fix the problem with Netflix?
Message posted on 24 Jun 2024 10:15 PM
I have had this issue for the last month!
When will it be rectified?
Do we get a refund?
I'm paying for a service I cannot watch!
Message posted on 24 Jun 2024 10:16 PM
Re: Netflix on sky q will not load
Yes, unplugged all sky bixes and router.
All I get is a red spinning circle
