2507
This discussion topic is read only This discussion topic has been answered Discussion topic: Netflix has encountered an error. Code: tvq-st-102
Locked
This message was authored by: chris+sand
Re: Netflix often not working on SkyQ
I'm having same issue, no problems up to abot 3 days ago now just netflix Title screen with spinning loading circle.. I can unplug and reset apps and it works but as soon as I come out of netflix and try to log back in I'm back to same issue.. you can't tell me this is a resolution I have to try and live with unplugging my sky bix everytime i want to watch netflix?.. i can watch via firestick with no issues?
Avatar for Collinsc
Level 5 icon
This message was authored by: Collinsc
I agree- it is not acceptable
I assume this is why they are investigating rather than just saying "tough luck". Seems it's a tough one to get to the bottom of.
(I'm still blaming the bizarre Q wifi networking. If it can randomly disconnect from wifi and totally fail to reconnect then it can bugger up comms for an app quite happily)
Avatar for Collinsc
Level 5 icon
oh, where does it say they are still investigating?
thanks
in another long thread on this topic on here. You're welcome to do the searching yourself though.
This message was authored by: BaileyGB
Re: Netflix sporadically not loading
This is has been bought up in a separate stream with exactly the same issue. Sky are now involved and have bought in NETFLIX to investigate the route cause of the issue. It is still currently under investment.
This message was authored by: focaldepth
Re: Netflix on sky q will not load
Wow, I have had this problem on an off (mainly not working for months now)
None of the suggestions make any difference.
However selecting Paramount (I am not signed up for it) then back to Netflix worked.
At least for now....
Thanks to the original poster of this idea, I can't get quote to work.
Thanks @Paul+Ja Paul+Ja
This message was authored by: Antony04
Re: Netflix app crashing/won't load
I found an answer on the internet. If you open your bbc iplayer app on your sky q box then go to Netflix app it will work. I tried this and my netflix worked again
This message was authored by: MarkJ22
Thank you.
That's what I do. It's been discussed in this post previously but it's good to see it works for others
It's still not the way NF should work though 😬😬😬
This message was authored by: Nynja+Squirrel
Doesn't work for me. I can open and close any app, makes no difference. I can reset the box, the apps, nothing makes any difference. I can flush the dns on my router, nothing... Netflix will not load on my Sky Q box.
This message was authored by: Shandysmom
Hi @Kirsty+S27
I was intermittently experiencing the same issue with Netflix, hanging on the loading screen for so long I often gave up waiting and moved onto another streaming service.
Thank you, it worked.
Many thanks
Terri ☺️
This message was authored by: Jenna24
Netflix app not working
Hi,
When I try to get into Netflix it's moves to the Netflix branded page but then just has a red circle of doom. All other apps work. I have refreshed apps three times over the last couple of days and also completely shut off and rebooted twice.
Any other suggestions!?
Thanks,
Jenna
Re: Netflix app not working
@Jenna24 wrote:
Hi,
Thanks,
Jenna
Hi @Jenna24
First try rebooting your internet router.
Disconnect power lead for 30 secs and then reconnect.
Wait until the router is completely back up and running and then reboot the Q box again.
This message was authored by: Kazza17
Thanks for the advice, I loaded up bbciplayer, watched a bit then exited then tried Netflix again and it's back
Locked
Answered - Go to Answer
