2507
This discussion topic is read only This discussion topic has been answered Discussion topic: Netflix has encountered an error. Code: tvq-st-102
Locked
This message was authored by: Malcolm40
Re: Netflix Won't Load / Spinning Circle
Spinning circle ️
0634589946 6
SKUSKYHQW=00000000000000001000000001319385
problem started today. Thanks for your help 🙏
This message was authored by: paul698
Re: Netflix: Red Spinning Circle on Launch
Dear all,
I too am having the same issue, Netflix has been working fine, today, all I had was the red spinning circle!
I switched everything off, disconnected everything, for a while, sky would not recognise my router but fine now.
Still have the red spinning circle, I tried the settings, 0,0,1, but nothing came up, no secret menu!
How do I access so that I can at least try the app refresh!
Thanks all.
@paul698
Have you tried this that is marked as the answer in this topic:
https://helpforum.sky.com/t5/Sky-Q/Netflix-Red-Spinning-Circle-on-Launch/m-p/4694387/highlight/true#...
Thank you, yes, tried that, nothing worked 😞
What did you try, just to be sure?
@paul698 wrote:
Dear all,
Thanks all.
Don't choose settings. Hover on it and do 001Select
Thanks so much, all sorted now, I was pressing 001 but not select! Tried the app refresh and Netflix started, not straight away but it did start and all is good.
Thanks again 👍🏻
This message was authored by: Stiffi
Followed the instructions and it worked for that one occasion but next day spinning red circle is back on mini box.
When is Sky going to rectify this or compensate for lack of access?
This message was authored by: Gaynor8
Netflix isnt working
Netflix hasnt been working for several days now, is there an issue
Re: Netflix isnt working
Netflix is NOT Sky Go
I have moved your thread to a more appropriate forum
I am NeurodivergentFAQs: Sky Glass Sky Stream Sky Go Sky Plus
This message was authored by: Peter6911
Netflix will not load continuous red spinning circle unless I power down and reload
When signing into Netflix app it does not load, the red circle just keeps spinning, the only way I can get it to load is by powering down both tv and sky q box then powering back up again
@Gaynor8
Do you have a Sky Q box and are you seeing a spinning circle ?
Re: Netflix will not load continuous red spinning circle unless I power down and reload
@Peter6911
I've moved your post into a large thread discussing this very issue. Please also see the post (number 2) currently showing as the answer.
This message was authored by: Daisy07
We have been suffering this issue for months where we have days when it won't work suffice today I'm fed up and so decided to investigate and came across this thread.
will try this in the morning
This message was authored by: Farhad001
My Netflix is not working why is that
Locked
Answered - Go to Answer
