2507
This discussion topic is read only This discussion topic has been answered Discussion topic: Netflix has encountered an error. Code: tvq-st-102
Locked
This message was authored by: A+s+belal
A box not working
My sky q box is not turning on at all, after to restart the apps.
Re: Netflix: Red Spinning Circle on Launch
Check Device Power
Re: A box not working
Hi @A+s+belal   Try pressing the on button on the actual box. It could be because your remote has lost contact with the box. Hold down 7 & 9 until you see 4 flashes, then hold down 1 & 3 pointing at the box, line of sight and follow the instructions on screen.
This message was authored by: Rachael50
Re: Netflix Won't Load / Spinning Circle
I have followed the guide to reset the settings and now all my apps have vanished completely
please tell me how to install them
This message was authored by: B55ennerdale
Netflix not starting up
When I click on the Netflix icon Netflix page comes up but nothing else just a red circle like it's trying to load but nothing.
Re: Netflix not starting up
@B55ennerdale
I've moved your post into a large thread discussing this very issue. Please see the post (number 2) currently showing as the answer.
They will appear
note, this isn't the most likely way to get this working again.
This message was authored by: Robw330
Re: Netflix won't open just spinning no connection
@Steviez , just had the same spinning netflix for the last week. I tried all of the suggested fixes with no result. And then this worked ..
I went into "apps pin" and switched "on".  Then went to "netflix app", typed in pin, and it's working ! Don't ask me why though.
Hi @Robw330   This will be very interesting, you may have found a quick way of clearing the background memory, which is the problem. Let's hope that somebody confirms it. If you haven't done so already, fill in the form
This message was authored by: MyNameIsJim
Whatever Sky are doing to try and fix this is not only not working, but it seems to be affecting Prime Video now too. Videos don't play, then after about 30 seconds I get"something went wrong ." After that it works.
It's been months now, I don't think they're taking this very seriously.
I can't get Netflix to load on the mini box. I have called and spoke to someone and it hasn't solved
I can't get Netflix to load on my mini box. I have called Sky and the problem is still the same.
Re: I can't get Netflix to load on the mini box. I have called and spoke to someone and it hasn't so
@Anonymous
Is it displaying a red spinning circle?
This message was authored by: Chrismike01
Re: Netflix sporadically not loading
Netfli not loading sparodically on sky q.
Yes. Black screen, red spinning circle under the word Netflix
@Anonymous
In that case I've moved your post into a large thread discussing this very issue. Please see the post (number 2) currently showing as the answer.
Locked
Answered - Go to Answer
