Discussion topic: Netflix has encountered an error. Code: tvq-st-102
Message posted on 19 Oct 2023 09:37 PM
Re: Netflix often not working on SkyQ
Nor did I, but the HDMIs cause so many problems. Same process fixes the reduced brightness in UHD. Give it a go but don't rush the box.
Message posted on 19 Oct 2023 09:39 PM
@Famine+Resistant wrote:Nor did I, but the HDMIs cause so many problems. Same process fixes the reduced brightness in UHD. Give it a go but don't rush the box.
Fortunately mine works flawlessly so a poor testbed.
Is that reduced brightness on HDR?
Message posted on 19 Oct 2023 09:53 PM
It's both. Messing with the Black was my initial work around until I discovered the HDMI trick. Had a friend get a new Q box yesterday and I'm seeing him tomorrow and he's an Openreach engineer so I'll post an update on Saturday. Good luck fella.
Message posted on 20 Oct 2023 10:26 AM
Re: Netflix app crashing/won't load
Is anyone else still having problems with Netflix? Logging in is still intermittent!
Message posted on 20 Oct 2023 11:34 AM
Hi all,
Thank you for sending details to me as requested, the team continue to investigate with Netflix and will keep you updated as soon as I have more information.
Thank you.
Community Manager
Message posted on 20 Oct 2023 08:47 PM
Back to square one here, red circle syndrome on Netflix. Tried the Netflix app on the LG tv itself, that offered me an update, which I agreed to, but then up came the message no network connection🤷🏼♀️ It worked fine all day and evening yesterday on and off, but not tonight. I then went back to my ipad, installed the Netflix app, and up it came working fine, but won't on the tv. I'm finding this all very strange.......and frustrating!
Message posted on 20 Oct 2023 08:52 PM
I have the same issue Helena....one day it's fine...and the next is spinning icon again 😞
Message posted on 20 Oct 2023 08:58 PM
It's definitely hit and miss. I've done everything that's been suggested.
Sometimes it loads right up
Sometimes it has the red circle of death
Sometimes I get the red circle then the logo pulses and it loads.
My get out if it's stuck is to go to iplayer, open and close then NF usually works.
But that isn't right!!!
Message posted on 21 Oct 2023 12:00 AM
@Helena70 wrote:Back to square one here, red circle syndrome on Netflix. Tried the Netflix app on the LG tv itself, that offered me an update, which I agreed to, but then up came the message no network connection🤷🏼♀️ It worked fine all day and evening yesterday on and off, but not tonight. I then went back to my ipad, installed the Netflix app, and up it came working fine, but won't on the tv. I'm finding this all very strange.......and frustrating!
Nothing to do with the sky box then?
Message posted on 21 Oct 2023 09:53 AM
That's your LG TV not connecting to the internet and absolutely nothing to do with Sky. If it's using WiFi and not getting a very good signal that may explain the issue with Netflix on your Sky box as well.
Message posted on 21 Oct 2023 02:38 PM
Re: Netflix on sky q will not load
Same issue with the spinning ring. Tried everything mentioned in earlier posts but nothing worked. Opened another app (paramount) which worked, closed it down and tried Netflix again. This time it worked fine 👍
Message posted on 21 Oct 2023 02:53 PM
I knew I tempted fate a couple of weeks back when I said no issues since I rebooted the Sky Router.
Gone again this afternoon.
Message posted on 21 Oct 2023 03:48 PM
I tried all the re boot of router and Sky Q box. Opened another app still no joy.
Tried the participate in tests on my account and that cleared it.
Hadn't tried that before as this came up after my earlier post about fixed and didn't want to disturb anything while it was working.
Message posted on 21 Oct 2023 03:55 PM
@steve+bendell wrote:I tried all the re boot of router and Sky Q box. Opened another app still no joy.
So you turned that option off ?
Message posted on 21 Oct 2023 04:14 PM
Yes, sorry its not clear in my post.
