2507
This discussion topic is read only This discussion topic has been answered Discussion topic: Netflix has encountered an error. Code: tvq-st-102
Locked
This message was authored by: Mikanda1
Re: Netflix: Red Spinning Circle on Launch
Is there any expected time for the issue being solved permanently?
I'd expect an updated post, marked as the answer, from Sky when there is
Removing all devices online and then fully rebooting the Q box usually is a permanent fix.
I can imagine that whatever set of circumstances causes the issue can re-occur though.
Maybe, although if it is because of an expired authentication token (most likely?) then it should take a long time to come back up and hopefully has been resolved by the software update for the future.
Maybe 🙂
This message was authored by: Migsy1
Cannot access Netflix
Re: Cannot access Netflix
@Migsy1 are you seeing a spinning red circle ?
Yes, it just keeps spinning round and round
Hi @Migsy1
Are you seeing the rotating red circle?
If you are see the following thread.
https://helpforum.sky.com/t5/Sky-Q/Netflix-Red-Spinning-Circle-on-Launch/m-p/4428388#M602362
This message was authored by: Emily2024x
When I load Netflix up it just goes round in circles and loads and loads for hours and doesn't do anything, can you help?
@Emily2024x
Have you tried this:
https://helpforum.sky.com/t5/Sky-Q/Netflix-Red-Spinning-Circle-on-Launch/m-p/4510468#M620067
This message was authored by: DeathBcomesHer9
Netflix through sky q not working .... death circle is all we get!
For over a week netflix not loading!!! Have updated software version multiple times ! And the usual reset box at wall! But it works on phone and tv LG just not from sky Q app
This message was authored by: Ernie73
Netflix not working on 1 mini box
One mini box does not load Netflix. This has been ongoing for some time. Just spinning cicle on Netflix logo screen. How do I fix this?
Re: Netflix not working on 1 mini box
@Ernie73
I've moved your post into this lengthy thread discussing this. For starters see post 2 currently showing as the answer.
This message was authored by: Quest2024
Cannot load Netflix on sky q box
I'm unable to load Netflix on my sky q box, but it loads on the sky mini box and tablets. I signed out of one of the tablets, but it's still not loading. It's stuck on Netflix logo and loading sign.
Locked
Answered - Go to Answer
